email notification when workbench is successful/failed
  • July 22, 2015
  • 55 views
parashari
Just a simple query to make things easy at the workplace.
I am working on Windows7 machine, 8Gb RAM, FME2015 x86  SP1. Sometimes, it takes hours for an FME workbench to run completely. I just want an email notification for the WB completetion(successful or failed) so as to run other process in the queue(internet connection available 24x7). Is that possible with FME.!!?
Shivam.
  • July 22, 2015
Hi
You can do this from a shutdown script, check for fme.status == True to know whether the workspace failed or not.
More info here: http://docs.safe.com/fme/html/FME_Workbench/FME_Workbench.htm#Configuration/FME_END_PYTHON.htm%3FTocPath%3DFME%2520Workbench%7CUser%2520Interface%2520Reference%7CWorkspace%2520Navigator%7CWorkspace%2520Parameters%7CStartup%2520and%2520Shutdown%2520Python%2520Scripts%2520%2520(Advanced)%7CFME_BEGIN_PYTHON%2520and%2520FME_END_PYTHON%7C_____2
An easier solution without any programming might to create a new workspace that calls your existing workspace using a WorkspaceRunner. You can then attach something like a Tweeter (built-in) or PythonEmailer (FME Store) transformer to send you a message according to how it went.
David
parashari
  • July 23, 2015
Hi David, Thanks for your suggestion.
So, I used SQLCreator,WSRunner and PythonEmailer. The error logged was...
Python Exception <gaierror>: [Errno 11004] getaddrinfo failed
Error encountered while calling function `email'
PythonFactory failed to process feature
I guess all other transformers have run successfully, but it has not executed the PythonEmailer. The parameters i used are as per below attached file...
Shivam.
  • July 23, 2015
Hi
Your server settings are wrong. Have a look here for details on how to connect to Google's SMTP servers: https://support.google.com/a/answer/176600?hl=en
David
parashari
  • July 23, 2015
Hey David. That was amazing. Did That. :) Thanks.
