Download dataset expired
  • October 31, 2013
  • 67 views
The zip file sent by email from download data service , expire after a day from the date of sending the email , how can we conrol this duraction to allow the link to be working for a week .
  • October 31, 2013
You can set the lifespan of the results by setting the FME_RESULT_LIFETIME in the configuration-file of each Engine. <FMEServerDir>\\Server\\fmeEngineConfig*.txt
The value is in seconds, so 1 week is 604800.
Thomas
  • November 1, 2013
for reference, here is the documentation for the FME_RESULT_LIFETIME setting provided by Thomas:
http://docs.safe.com/fme/2013/html/FME_Server_RefManual/Content/Engines/config_file_layout.htm
There are other settings there that might be good to know about, too.
David
