Directory watcher to trig a single event for multiple las file
  • Aug 24, 2023 1:38 AM UTC
  • 90 views
magda_cz
I created a workspace to process las files and receive raster and contours data set. The workspace supposed to be run with use of a directory watcher but it looks every las file is a trigger to run it again. Is there a way to have a single event with FME Server 2020.2? Thanks
Best answer by keziaatsafe
Hi @magda_cz​ ,
The Directory modified trigger does not support multiple file dataset. The file modified triggers are designed to send one message to the Automation per create/modify/delete event, this means the downstream action will run for every single file change regardless of whether they were uploaded together. There is no way to merge these but please see this article for potential workarounds.
I also found this idea on our Ideas page. Please upvote and comment your use case to improve the feature.
Here is one more community post with a similar question for more context.
Hope this helps!
Kezia
keziaatsafe
Forum|alt.badge.img+8
  • Aug 25, 2023 9:12 PM UTC
Hi @magda_cz​ ,
Hope this helps!
Kezia
magda_cz
  • Sep 5, 2023 1:55 AM UTC
Hi @magda_cz​ ,
Hope this helps!
Kezia
Thanks so much @keziaatsafe​ for your reply!
