Detection of mismatches in the number of lines that adjoin each other
  • Jul 5, 2017 3:45 PM UTC
  • 78 views
I need to detect if there is a mismatch in the number of polylines that adjoin each other. For example one polyline in the middle, four either side (or it could be any number of mismatches: 3-2-3 for example. Polylines aren't snapped together; it's for a powerline project so it's not a requirement.
I can group the lines together and assign them grouped id's together using the attached process.
One final point; I only need to calculate the relationship of polylines that have 'neighbours' on either side and not on polylines with only one set of 'neighbours' (see below)
lars_de_vries
Forum|alt.badge.img+10
Hi @kyle_d_wade,
I am not sure whether I understand your question correct, but I think you want to know whether a certain polyline has neighboring polylines, but you also mention whether lines are connected to each other. Looking at your data, I assume that the parallel polylines are offsetted perpendicular to the other ones. I do not see an attached process, only images, so that does not help either.
Could you describe the different steps you want to test? I think that will help in finding the correct solution.
Hi @kyle_d_wade,
If there is four lines in group 1, one line in group 2, and four lines in group 3 how do I detect if there are less lines in group two compared to groups 1 and 3 (more lines on either side)? The lines aren't snapped together. I have managed to count how many wires are in each group with Statistics Calculator.
