Data Streaming direct URL
  • Nov 3, 2018 6:02 AM UTC
  • 40 views
boubcher
Forum|alt.badge.img+11
need to use this link in My APP, how can I run the direct link without having to enter the username and PW,
I assume this is using the guest user credential,
Thanks
boubcher
  • Nov 3, 2018 6:24 AM UTC
when edit the guest account its asking me to enter the credentials
danilo_fme
Forum|alt.badge.img+58
  • Nov 3, 2018 4:09 PM UTC
Hi @boubcher
You can use Token in the URL instead login and password.
https://knowledge.safe.com/questions/34768/how-can-i-share-a-fme-server-resource-file-easily.html
Please, tell me if is good in you case.
Thanks,
Danilo
Hi @boubcher,
In the FME Server Security you can give the fmeguest role access to run that workspace (under Repositories) and then you will no longer be asked to provide a password when you run the job using the direct URL.
