data download service no data download url?
  • Apr 7, 2017 4:57 AM UTC
  • 17 replies
  • 226 views
austinDownload.fmw sample is producing a data download url, a zip in the engineresults directory and writing features
mine is writing features (no log error) but no url or zip in the engineresults directory
I'm a newb with FME Desktop and Server and don't know where to start.
Best answer by richardtriesfme
Our reseller recommended running the scripts as per No. 3 here
https://docs.safe.com/fme/html/FME_Server_Documentation/Content/AdminGuide/Post-Config-Scripts.htm
Problem solved with Data Download edit button no longer grayed out.
itay
Forum|alt.badge.img+19
  • Apr 7, 2017 5:59 AM UTC
ciarab
Forum|alt.badge.img+10
  • Apr 7, 2017 6:31 AM UTC
Just select the service data download when you publish the workspace and also when you go to run it and you will get the url
I am selecting data download and job submitter although the edit options for data download are grayed. When I run the sample I get a url but with mine I don't. When I publish the AustinDownload myself it's also not returnng a url. However, the existing AustinDownload sample does return a URL.
I verified my install which is valid seeing as I can run workspaces no problem.
itay
  • Apr 7, 2017 6:49 AM UTC
Are you using a user with the correct priviladges?
ciarab
  • Apr 7, 2017 8:40 AM UTC
Has someone changed your server host name or port recently?
https://knowledge.safe.com/articles/277/service-properties-are-unavailable-when-uploading.html
yes for testing I'm using my fmeadmin account which is in the fmeadmin and fmesuperuser roles
todd_davis
Forum|alt.badge.img+23
  • Apr 9, 2017 11:57 PM UTC
Taking a step back...How did you create the data download service? When you uploaded the FMW onto FME Server, did you choose data download and then "Edit". Under the next dialogue did you choose the data that you wanted returned?
data download is selected but the Edit button is grayed. Job submitter is selected and Edit button is not grayed.
todd_davis
  • Apr 10, 2017 12:02 AM UTC
Is this using the Austin Sample or your current workspace? If it is your workspace, can you see what the happens when you try the Austin one?
Austin Sample creates features and a zipped url. Mine creates features but no zipped url.
todd_davis
  • Apr 10, 2017 12:07 AM UTC
Sorry, I mean when you open the Austin workspace in FME and go to publish it, selecting data download, does the Edit button highlight.
What I am trying to confirm is that you have a writer in your workspace, because that would be a reason why the edit button could grey out?
If I publish austinDownload.fmw the datadownload edit button is grayed and no url is produced i.e. same behaviour as my workspace.But, if I use the pre-existing austinDownload.fmw from the Samples directory a url is produced.
Also no zip file is being produced in the engineresults directory
todd_davis
  • Apr 10, 2017 12:22 AM UTC
So we can firmly point the finger at the server and some network issue. So it might be as @ciarab mentioned or something else happening in there.
No host and port remain the same. We have however upgraded from 2016 to 2017 fme server. . The config was returning a url in 2016.
