Check transformers used in a workbench without opening the workbench
  • Jul 26, 2022 12:59 PM UTC
  • 70 views
We have thousands of workbench that need a round of audit to check whether the workbench contains certain transformers. Is there a way to programmatically check this without having to open the workbench themselves?
nielsgerrits
Forum|alt.badge.img+67
You can use the Workspace reader to do this.
As an alternative, you can read the workspace as text, but this is more advanced.
@lgyyyq13​ There is a workspace here that uses the Workspace Reader suggested by @nielsgerrits​ and returns quite a bit of information about your workspace, including the versions of the transformers. You can just point at a folder with all your workspaces.
