Can we get process id of particular service starts through System Caller? Or can we trigger CLI request with user defined Process Name through System Caller?
  • March 10, 2021
  • 5 replies
  • 89 views
rejith3119
I am using system caller in child workbench which trigger 3rd party service using command line and start the process e.g. abc.exe in windows. Sometimes process get stuck at their server and I am not able to get the status of the same, hence child workbench continue until any response gets from System caller. Is there any solution to kill the 3rd party process using windows process name or ID if its taking more than a particular time e.g. 1 hr?
Note: I am using FME Desktop with concurrent process of 3 jobs, so it should kill only the process which are not getting finished within 1 hr.
Can anyone help me on this?
Best answer by david_r
The SystemCaller is fairly simple and it doesn't return the process id.
For your use case, I would recommend using the PythonCaller rather than the SystemCaller.
Starting point:
import subprocess
def ProcessFeature(feature):
    process = subprocess.Popen(["echo", "hello"])
    print(process.pid)
  • March 10, 2021
Starting point:
import subprocess
    print(process.pid)
rejith3119
  • March 10, 2021
Starting point:
import subprocess
    print(process.pid)
Hi @david_r​ ,
     Thank you for the quick response. I will try this one and will get back to you with the updates
rejith3119
  • March 12, 2021
Hi @david_r​ ,
Hi @david_r​ ,
I am a fresher in python, so after exploring https://docs.python.org/3/library/subprocess.html#frequently-used-arguments, I could run below code with hard coded arguments like subprocess.Popen(["abc.exe", "arg1","arg2",....]), but its failing when I am running using 'arg' variable where cmd = ["abc.exe", "arg1","arg2",....]. Is there any syntax error?
import subprocess
def processFeature(feature):
  arg = feature.getAttribute('cmd')
  proc = subprocess.Popen(arg)
  feature.setAttribute("process_id",proc.pid)
  try:
    outs, errs = proc.communicate(timeout=120)
  except subprocess.TimeoutExpired:
    proc.kill()
    outs, errs = proc.communicate()
    feature.setAttribute("IsFailed","T")
Thanks in advance
  • March 12, 2021
Hi @david_r​ ,
Just make sure 'arg' is a list, not a string. The function feature.getAttribute() does not return a list, unless you're referencing an FME list attribute.
rejith3119
  • March 15, 2021
Hi @david_r​ ,
Thanks @david_r​  list method worked😊
