Can a datadownload from FME Server start without returning the download link?
  • February 16, 2017
  • 5 replies
  • 42 views
erik_jan
Forum|alt.badge.img+26
I uploaded a workspace to a FME Server using the Datadownload service.
I call this service and workspace from a custom webpage.
All is working as designed, but I would like to skip the download link that is returned by the service.
I would like the Datadownload service to start downloading the file as soon as the file is generated.
I can't find the right option for this.
My URL looks like: http://localohost:8080/fmeserver/fmedatadownload/myrepository/myworkspace.fmw?
Can anybody help?
Best answer by fmelizard
The data streaming service will zip multiple file output and the download will start as soon as the workspace completes.
itay
Forum|alt.badge.img+18
  • February 17, 2017
Do you have to call it from a webpage? if you can call it from a workspace then it should be easy to set up a httpcaller to use the download link.
  • February 17, 2017
If your custom web page uses an XMLHttpRequest to trigger the Datadownload service, you could include an event handler that intercepts the download URL returned from FME Server and then download using something like this: https://ausdemmaschinenraum.wordpress.com/2012/12/06/how-to-save-a-file-from-a-url-with-javascript/
fmelizard
Forum|alt.badge.img+21
  • February 18, 2017
erik_jan
  • February 20, 2017
HI @aaronkoning: I tried this and ended up with this error:
"Failed to extract or package datasets at output location: C:\\ProgramData\\Safe Software\\FME Server\\resources\\system\\temp\\engineresults\\FME_4452076C_1487603043638_6128"
when I downloaded a zipped Shape file.
erik_jan
  • February 20, 2017
And I found the output data in a subfolder of:
"C:\\ProgramData\\Safe Software\\FME Server\\resources\\data"
