Add my own attributes to Webhook JSON-response?
  • October 18, 2023
  • 15 views
I'm looking for a way to add my own key:value pairs/object to the Webhook JSON-response.
The default webhook JSON response is:
{"serviceResponse": {
   "jobID": 294,
   "statusInfo": {
      "mode": "sync",
      "status": "success"
Woud like to add something like:
   "jobID": 294,
   "statusInfo": {
      "mode": "sync",
      "status": "success"
   "productData" : {
      "productVariant" : "type1" // = $(productVariant)
 Not sure if it is possible at all. All suggestions are welcome.
Thanks!
siennaatsafe
Forum|alt.badge.img+11
Hi @michielzoer​ ,
The only way I can think of to customize the JSON is to create another writer in your workspace and use the data streaming service to send JSON back to the user.
In FME, you can write JSON. Then, you can set up the data streaming service to stream the JSON. 2023-10-20_13-14-50Then, you can step up a webhook using the data streaming service. Please Part 2: Webhook URLs and the Data Streaming Service in this article.
