Zip a File GDB but exclude a named Feature Class
vxn43
Forum|alt.badge.img+18
I am using FME Form 2021.
I have completely re-written this post. What is the best approach to zip all Feature Classes in a File GDB without having each Feature Class show up individually in the workspace? I have 25+ Feature Classes and do not want them all to show up separately. Just want to zip up my File GDB.
Sorry about the incorrect subject header.
Best answer by takashi
Hi ​@vxn43 ,
I think File Copy writer can be used to create a zip archive containing File Geodatabase dataset (*.gdb).
  1. Create a feature which has an attribute named "filecopy_source_dataset" storing the target File Geodatabae dataset (*.gdb) path.
  2. Connect the feature to a File Copy writer, and set the writer parameters as in:
    • Dataset : Add suffix ".zip" to the destination folder path.
    • Surfolder Name : A preferable subfolder name. You can set "." if you don't need to use subfolder.
    • Copy Source Folder : Set "Yes".
Instead of regular writer, FeatureWriter (Format: File Copy) can also be used, as shown below.
vxn43
  • April 19, 2025
I found the answer. Seeing is believing. It works!
This workspace grabs a File GDB and zips it up to folder of my choice.
This method works best for zipping entire File GDBs with many Feature Classes; in my case, I have 22 Feature Classes. If you have only a couple of Feature Classes, you could zip the File GDB using a File GDB Reader, which will bring in each Feature Class as a separate Reader into your workspace. You then add separate File GDB Writers for each and choose the Zip option in the Writer.
Does anyone have a different way to do this? Curious to know.
Feature Writer Parameters from above screen capture:
  • April 19, 2025
Hi ​@vxn43 ,
