Writing data to temporary folder
  • November 27, 2019
  • 64 views
jessebridge
Hi all,
Is there a way to write a csv to the temporary directory of the fme cloud server and use that file as an attachment? i am using the ($shared_resource_temp) server parameter to identify where the file should be written but this is not writing the data to the temporary directory.
Cheers
Best answer by nielsgerrits
Yes you can. The TempPathCreator is the transformer that can fix your temp location.
nielsgerrits
Forum|alt.badge.img+54
