Writing Autocad region object (FME 2018 beta)
  • Jan 9, 2018 3:20 PM UTC
  • 77 views
I've heard very good news that FME can now read/write autocad regions and I am trying to test it using FME 2018 Beta. I have no problem to read an autocad_region however after several attempts I am not able to write an autocad region. I’ve already tried creating donuts, area or surface in a workspace and writing it to a .dwg file as a region but each time FME creates an autocad_block instead and not a region. If anybody was successfully able to write a region, I will be glad if I can have a simple example/guide on this subject.
Many thanks
Regards,
Hani
gio
Forum|alt.badge.img+15
  • Jan 9, 2018 5:13 PM UTC
regions are surface objects. You can convert the polygons using a facereplacer.
not tried in fme2018 beta though.
fmelizard
Forum|alt.badge.img+22
  • Jan 9, 2018 6:55 PM UTC
Hi @hzahiri,
The DWGStyler now has the option to create Autocad Regions. It is under the Areas section (see below).
In a simple test I created a box object with the creator, used the DWGStyler with the below settings and then wrote out using the RealDWG writer. I was able to confirm in AutoCAD that a region was created.
Perhaps your region is a little more complex which may require some tweaking. Are you able to share a sample of what you're working on or what you want to turn a region?
  • Jan 10, 2018 1:22 PM UTC
Hi
Matt and Gio, many thanks for your replies.
@MattAtSafe, I've tried your solution and it works for RealDWG writer however what I want is writing to a DWG. in case of DWG, I've still a block instead of a region. You may find my test case and what I am expecting as attachments. Again thanks for your help.
Regards,
Hani
test-region.dwg
test-region-result.dwg
