Write down values from one column to another based on rule
  • Nov 21, 2019 2:44 PM UTC
  • 60 views
Hello everyone, I need help. I got excel with data that looks like this picture. So, I have two blocks in excel name "CR" and "M". I need to compare attribute "Ownerstag" from block "M" to attribute "Location" from block "CR" and if they are the same then I need to write values from attribute M (column J) from block "M" in attribute "Location" from block "CR". Thanks in advance.
Best answer by redgeographics
You'll first need to split your dataset based on the Name field, you can use an AttributeFilter for that, and then use a FeatureMerger to join them back together again, based on Location/Ownerstag. Then finally an AttributeManager to put the value of field M in Location.
Forum|alt.badge.img+63
