WorkspaceRunner Alternative
  • June 25, 2014
  • 26 views
I have a workflow which has
1. Genereric Reader
2. Sampler - Which will send onle 1 feature
3. GeometryFilter- To decide geometry type of source data possible values are Polygon, Point and non-geom data
Now I have 3 different workspaces for above 3 conditions. To decide which workspace to run I have written a shutdown python script which will run WorkspaceRunner and it will decide which workspace to run. but I am not able to use vaiable I set in workflow to decide the workspace.
In short I need to use variable defined in workflow in Python script?
Note: I don't want to use WorkspaceRunner as I am publishing this to FME server.
  • June 25, 2014
A PythonCaller with a script which define a Python global variable can be used.
# PythonCaller Script Example
import fmeobjects
def processFeature(feature):
    global g_value
    g_value = feature.getAttribute('AttributeName')
You can then access the global variable (g_value) in the Shutdown Python Script.
Hope this helps.
Takashi
  • June 25, 2014
Thanks Takashi. That's wroked well.
