Workspace log file is remembered !?
  • September 6, 2017
  • 20 views
lifalin2016
Forum|alt.badge.img+40
I recently needed to run the same workspace (command line) with two different target setups, but I wanted to see separate log files for each run. Simplified example:
fme.exe myworkspace.fme --p1 ABC --p2 DEF
fme.exe myworkspace.fme --p1 XYZ --p2 KLM
So I had FME create a workspace parameter (--LOG_FILE) for this value. This value is normally blank, prompting FME to use the workspace file path with "log" extension.
I.e. my setup had the first run without a value, and the second run with a value for the log file..
However, I found out, that the value given in the second run are somehow reused in the first run at a later time !?!
Is this a correct observation, that FME somehow caches the last parameter values given to the workspace, and reuses these whenever the same workspace is run at a later time (and no other values are provided) ??
I got my two runs to work only when both set the "LOG_FILE" parameter.
Cheers.
Best answer by david_r
If you leave a published parameter blank on the command line, it will use the default value for that parameter, which is normally the last value used when saving the workspace file.
Could that possibly be the issue here?
  • September 6, 2017
lifalin2016
  • September 7, 2017
Well, the workspace isn't re-saved between the runs, so it's not that obvious, unfortunately.
