workflow managment
  • Oct 26, 2015 6:45 AM UTC
  • 58 views
Hi
Is it possible to use FME cloud instead of FME server for work flow managment?  ie run chained work flows which rely on the output of the previous step/s
Many Thanks
Lucky
Best answer by david_r
Hi
FME Server and FME Cloud is basically the same thing, the difference being that FME Server runs on your own infrastructure (servers), whereas FME Cloud runs in the, well, cloud :-)
So yes, you can chain jobs on FME Cloud the same way as on FME Server.
David
  • Oct 26, 2015 9:31 AM UTC
Hi
David
