Why with a Startup python script work in workbench but not in FME SErver
  • Nov 26, 2019 2:41 PM UTC
  • 6 replies
  • 134 views
billybob
I have a a startup python script that will execute in workbench, but after being published to fme server fails when connecting to the SDE workspace. See image below. Any ideas why this might occur?
Thanks,
Frank
Here is the startup python script which executes in workbench and not in fme server:
# Name: DisableEditorTracking.py
# Description: Disables editor tracking on a feature class.
# Import modules
import os, arcpy
# Local variables:
TrackingFeature = "GIS.address"
# disconnect users
admin_workspace = r"C:\\Users\\Administrator\\AppData\\Roaming\\ESRI\\Desktop10.7\\ArcCatalog\\SQLDEV_sde_wilco.sde"
arcpy.DisconnectUser(admin_workspace, "ALL")
# assign workspace environment
workspace = r"C:\\Users\\Administrator\\AppData\\Roaming\\ESRI\\Desktop10.7\\ArcCatalog\\SQLDEV_gis_wilco.sde"
arcpy.env.workspace = workspace
# Disable Editor Tracking
arcpy.DisableEditorTracking_management(TrackingFeature,
"NO_DISABLE_CREATOR",
"NO_DISABLE_CREATION_DATE",
"DISABLE_LAST_EDITOR",
"DISABLE_LAST_EDIT_DATE")
Best answer by david_r
And does the service user that's running the FME Server Engines service have the necessary access rights to this file? I'm asking since it's located in a user profile, which by default is private.
Perhaps try moving the .sde connection file to somehwere "neutral" like c:\\temp and see if that makes a difference.
  • Nov 26, 2019 3:26 PM UTC
Does the following file exist on the machine running FME Server?
C:\Users\Administrator\AppData\Roaming\ESRI\Desktop10.7\ArcCatalog\SQLDEV_gis_wilco.sde
billybob
  • Nov 26, 2019 3:37 PM UTC
Yes, it does. ArcGIS Desktop 10.7.1 is installed on the server running FME server, and both the connection files shown in the script are available.
  • Nov 26, 2019 3:45 PM UTC
billybob
  • Nov 26, 2019 6:01 PM UTC
So, two things. Sorry, I probably wasn't clear, but the startup script executes without an error when run in workbench on the same server that has fme server installed. It access the same location for the .sde connection file. The other is that this workspace has executed correctly for about a month, but now is failing. I'm using FME Server 2019.1.3.1 (Build 19643).
billybob
  • Nov 27, 2019 2:03 PM UTC
@david_r, Your suggestion was correct. Even thought the workbench worked correctly , i move the connections to a network share drive where the FME Server has access and the scripts executed correctly! Thanks for your suggestion. I really appreciate the help!
