Why can't the FeatureWriter with File Copy writer be included into Data Download?
Hello,
FME 2020.0
The screenshots below describe the question.
Best answer by hollyatsafe
Update: This issue has been resolved for FME 2022.0.
Hi @takashi and @warrengis,
I'm sorry that you encountered this bug, it is known to Safe (FMESERVER-13767). I will assign this Community post to the issue so that you can be notified when it is resolved.
warrendev
Forum|alt.badge.img+23
  • May 4, 2020
I ran into this issue as well. Would be nice to be able to select the FileCopy FeatureWriter, as you can select all other feature writers that aren't set as a filecopy. I'm on 2020.0.0.1
  • May 4, 2020
