Where is the Insert Constant tool?
  • November 2, 2015
  • 40 views
tnarladni
Forum|alt.badge.img+16
There used to be a functionality that you could add a constant on the workbench and connect it to a field in the writer and it would be added as a value to that field. Has that been replaced by a transformer? If so, what?
  • November 3, 2015
Hi
Right-click on the writer attribute and select "Edit value..."
After
Personally, I prefer using an AttributeCreator (or the like), though.
David
