Where is the Insert Constant tool?
  • Nov 2, 2015 8:03 PM UTC
  • 77 views
tnarladni
Forum|alt.badge.img+24
There used to be a functionality that you could add a constant on the workbench and connect it to a field in the writer and it would be added as a value to that field. Has that been replaced by a transformer? If so, what?
  • Nov 3, 2015 7:40 AM UTC
Hi
Right-click on the writer attribute and select "Edit value..."
After
Personally, I prefer using an AttributeCreator (or the like), though.
David
