Where is propertiesFile.properties
  • October 16, 2017
  • 30 views
rob_datavision
I download FME server from the FME web site today October 16 2017 (FME Server 2017.1.1 64-bit windows FME Server build 17650)
I am setting up an active/passive architecture. Mostly as derscribed on the web site https://docs.safe.com/fme/2016.1/html/FME_Server_Documentation/Content/AdminGuide/Active-Passive-Basic-Architecture.htm Everything has been going as described until after I setup the FME web services a third windows server 2016 VM. For the web application server I chose the FME Server Web Application Server (port 8080) I get stuck when I get to the first step in configuring the FME server for Failover. I can't find the web application properties file (propertiesFile.properties) specified as step 1 after the windows install at https://docs.safe.com/fme/html/FME_Server_Documentation/Content/AdminGuide/Install-the-FME-Server-Web-Services.htm#Install. I suspect its in <FMEServerDir>/Utilities/tomcat/webapps/fmedatastreaming/WEB-INF/conf/ but I can't find fmedatastreaming in <FMEServerDir>/Utilities/tomcat/webapps (FMEServerDir is the default c:\\Program Files\\FMESever) Do you think you could help me find this file please?
Best answer by rob_datavision
I did a uninstall and reinstall of FME web services and the file now appears. The only thing I did differently is to specify fully qualified domain name for VM. The location of the file is as per the documentation.
Thanks, this is no longer an issue.
rob_datavision
  • October 16, 2017
rob_datavision
  • November 3, 2017
Actually this has more to do with the correct setup of the service account. The service account must have logon as a service rights and must have full control of the installation directory. The last point is noted in one of the installation dialog boxes.
By the time I had done the second install, these requirements were met and so it made it seem like an install and uninstall fixed the problem.
