What is the best way to stop a workspace if a NULL value exists in field?
  • May 15, 2024 6:39 PM UTC
  • 217 views
kmc5678
Forum|alt.badge.img+4
I have a workspace that sends data to a url through the HTTP Caller transformer. I want to terminate the workspace if a NULL value exists in a field that is in a table on a SQL database before the data is sent. What is the best way to do this? Do I still need the Creator transformer if I use a Tester?
Best answer by liamfez
You could use a Terminator after a Tester (testing for a NULL). Yes, you would still need a Creator to start things off in that case.
liamfez
Forum|alt.badge.img+44
  • May 15, 2024 7:31 PM UTC
kmc5678
  • May 15, 2024 7:46 PM UTC
Thanks @liamfez, This is what I was thinking.  Would I connect the Passed Tester to the first HTTP Caller and then connect the Failed Tester to the Terminator (below)?
liamfez
  • May 15, 2024 7:54 PM UTC
Assuming you have the Tester set up so that features that are not NULL are Passed, then yes. If a NULL feature exits the Failed port, it will then terminate translation. You can add custom messages in the Terminator to provide more information, like a short message detailing why translation was terminated, which will go to the log.
I initially misunderstood your question about the Creator. How you have that screenshot you then do not need the Creator. The reader will provide the features.
