VariableRetriever works correctly?
  • February 26, 2018
  • 8 replies
  • 47 views
gtitz
Forum|alt.badge.img+3
Hi!
I set a variable in the Startup Python Script:
import fme
from datetime import datetime
fme.macroValues['workbench_started'] = datetime.now().strftime("%Y%m%d%H%M%S")
The first version of the workbench looks like this:
This is the result - there is no current-date-time-value in the attribute _value:
So, in my opinion the VariableRetriever didn't work correctly.
Alternative solution, use the python caller to retrieve the variable and set attribute:
This is the code of the PythonCaller:
import fme
import fmeobjectsdef processFeature(feature):
    feature.setAttribute("_value", fme.macroValues['workbench_started'])
This is the result:
It looks like the VariableRetriever isn't working properly.
Or did I make something wrong?
I have tried it in FME Desktop 2018.0 and FME Desktop 2017.1.2.0.
  • February 26, 2018
Any reason not to use a Private User Parameter as a Scripted (Python)  called "workbench_started"
return datetime.now().strftime("%Y%m%d%H%M%S")
Then just reference the User Parameter
  • February 26, 2018
The variables set using the VariableRetriever / VariableSetter aren't available from the Python API, unfortunately. As far as I know there are no methods for manipulating them using Python. See also here: https://knowledge.safe.com/questions/2263/python-global-variable.html
The dictionary "fme.macroValues" (and the global dictionary "FME_MacroValues") references the private and published parameters of the workspace, not the variables.
gtitz
  • February 26, 2018
Thanks for you reply, but sorry, I don't know what you mean?!
gtitz
  • February 26, 2018
Thanks! Over your link, I came to this site:
I think, I will set a global variable by the startup python script. In the workflow I will read the global variable with a python caller and set the value to an attribute of the features.
  • February 26, 2018
If you simply need the timestamp for when the workspace started, here's a maybe simpler solution:
  1. Create a private parameter of type "Scripted (Python"
  2. Inside the private parameter, insert the code suggested by @davidrich
  3. In your workspace, use the ParameterFetcher whenever you want to reference the startup timestamp.
This way you won't have to use Python global variables.
  • February 26, 2018
Then change type to Scripted (Python)
Name as "Workbench_started"
and paste the code in the Value
then should be able to access "Workbench_started" anywhere in the workbench
gtitz
  • February 26, 2018
Ah, great! "Scripted (Python)" was the hint I needed! Thanks! :)
gtitz
  • February 26, 2018
Yes, you are right! That's the better solution. Thanks! :)
