I'm struggling a little bit with using trying to build in a variable reader schema. I've built the workbench where it prompts the user for the source shape file. I received a sample of the schema but there is a good chance of a different shapefile schema being input.
I have tried working with the knowledge base but I'm coming up short. The output is a known schema I've created after the analysis.
Does anyone have any ideas?
