Using the PythonCaller to extract substring between two known substrings
peteralstorp
Forum|alt.badge.img+5
Hello, fellow FMEers.
I'm very new to Python and to the PythonCaller, but we all need to start somewhere. I have wrestled with this problem basically all day and I still don't get it to work.
I have a textstring "A=0,5m, B = Bredd 0 m, C= Reduktionstal". From this string I want to extract the value between "Bredd " and " m" - in this case it is 0, but in can be 10, it can be 10.2.
I'm attaching an image of my progress so far... And the PythonCaller script so far:
import fme
import fmeobjects
import re
def FeatureProcessor(feature):
substr = re.search('Bredd (.*) m', feature.getAttribute('text'))
feature.setAttribute("substr", substr)
I have often come across this problem and I really want to learn how to solve it. Pls help!
Peter
Best answer by takashi
Hi Peter,
I would also use the StringSearcher in this case. However, if you want to learn Python regex operations, it's also a good practice of course. There could be some possible implementations, this is an example.
import fme
import fmeobjects
import re
    m = re.search(r'Bredd\s*(\d+\.?\d*)\s*m', feature.getAttribute('text'))
    if m:
        feature.setAttribute('substr', m.group(1))
The editor is not good. A backslash before the dot in the regex cannot be displayed. Please insert a backslash before the dot!
Bredd\s*(\d+\\.?\d*)\s*m
Note that the "re.search" method returns a MatchObject instance, not a matched substring.
See here to learn more about regex operations with Python.
https://docs.python.org/2.7/library/re.html#module...
Takashi
  • November 12, 2015
Hi Peter,
try this:
nameOfYourStr="A=0,5m, B = Bredd 0 m, C= Reduktionstal"
start=nameOfYourStr.find('Bredd ')+6
end=nameOfYourStr.find(' m, C=')
substr=nameOfYourStr[start:end]
Yann
  • November 12, 2015
Hi
You do not have to use Python for this, a simple StringSearcher will suffice. Use the expression
Bredd\s*([\d.]+)\s*m
And you will get your value as _matched_parts{0}
David
  • November 12, 2015
Hi Peter,
In one line:
feature.setAttribute('substr', feature.getAttribute('text').split('Bredd')[1].split('m')
[0].strip())
And step by step:
#Get the text attribute
att = feature.getAttribute('text')
#Right part of Bredd
right = att.split('Bredd')[1]
#Left part of m
left = right.split('m')[0]
#Trim extra spaces
substr = left.strip()
feature.setAttribute('substr'substr)
Larry
  • November 13, 2015
Hi Peter,
import fme
import fmeobjects
import re
    if m:
Takashi
  • November 13, 2015
Hello,
I made some performance measurement of all proposed solutions and here are the numbers:
Test case Nb. of features Run 1 Run 2 Run 3 Average PythonCaller + string.find 1 000 000 20.5 20.3 20.1 20.3 PythonCaller + string.split 1 000 000 20.5 20.4 20.9 20.6 PythonCaller + regex 1 000 000 23.3 21.8 23.6 22.9 StringSearcher 1 000 000 32.7 32.0 32.4 32.4
Larry
peteralstorp
  • November 13, 2015
yanntt wrote:
Hi Peter,
try this:
Yann
yanntt, thank you so much for your time. I am very grateful for this. Peter
peteralstorp
  • November 13, 2015
david_r wrote:
Hi
David
Thank you, david_r! I'm grateful that you took your time to answer this. Peter
peteralstorp
  • November 13, 2015
larry wrote:
Hi Peter,
In one line:
[0].strip())
And step by step:
#Left part of m
#Trim extra spaces
Larry
Larry, thank you very much for this enlightening answer. Very much appreciated. Peter
peteralstorp
  • November 13, 2015
takashi wrote:
Hi Peter,
import fme
import fmeobjects
import re
    if m:
Takashi
Takashi, thank you very much . This was perfect and educating for me. I will use this and solve all my string related problems in a flash. Much appreciated. Peter
peteralstorp
  • November 13, 2015
larry wrote:
Hello,
Larry
Interesting, Larry, in this case I only have about a thousand objects, but anyways, interesting. Thanks! Peter
  • November 13, 2015
larry wrote:
Hello,
Test case
Nb. of features
Run 1
Run 2
Run 3
Average
1 000 000
20.5
20.3
20.1
20.3
1 000 000
20.5
20.4
20.9
20.6
1 000 000
23.3
21.8
23.6
22.9
StringSearcher
1 000 000
32.7
32.0
32.4
32.4
Larry
Nice analysis, very helpful. I would suspect that the StringSearcher will be faster starting FME 2016, as the've replaced the Tcl regex engine with something (hopefully) more efficient. As you can see, the StringSearcher currently calls the Tcl engine for each feature that enters, leading to quite a bit of overhead.
For the sake of performance, you could also use a pre-compiled regex, it shaves off a couple of seconds:
precomp_regex = re.compile(r'Bredd\s*(\d+\\.?\d*)\s*m')
    m = precomp_regex.search(feature.getAttribute('text'))
    if m:
David
