Using REST API submit, how to send email
  • Oct 5, 2015 11:30 AM UTC
  • 9 replies
  • 165 views
Hello!
I'm developing a web application that sends requests to an FME server to run some pre-defined workspaces.
I'm passing in some parameters (including geometries as GeoJSON) as published Parameters, and I am using the rest API endpoint /fmerest/v2/transformations/commands/submit/REPOSITORY/WORKSPACE
This seems to work fine, I get a job ID back and the logs tells me that the job has run.
However, and here lies the problem: As these jobs can be long-running and I don't want the hassle of polling FME server from my web app I would like FME server to send the result as an email to an email-address specified when the job is submitted (IE: not hard-coded in FME server)
After some googling and chats with our FME experts it seems like this should be possible using the JobSubmitter service (http://docs.safe.com/fme/2014/html/FME_Server_Documentation/Default.htm#web_services/job_submitter_service.htm) and setting the opt_requesteremail property.
However: to my understanding the jobsubmitter only works with Query parameters, and not a POST body like in the /fmerest/v2/transformations/commands/submit/REPOSITORY/WORKSPACE endpoint. I want to use a POST body as I'm rather sure that I will have published parameters (GeoJSON polygons f.ex) that exeeds the maximum URL length)
So: the simple question is: How do I use the fmerest/v2/transformations/commands/submit/REPOSITORY/WORKSPACE endpoint and specify an email to send the result to?
I've tried setting NMDirectives.successTopics and NMDirectives.failureTopics to JOBSUBMITTER_ASYNC_JOB_SUCCESS and JOBSUBMITTER_ASYNC_JOB_FAILURE in the PostBody and adding opt_requesteremail and opt_servicemode=async to the URL, but it does not seem to work.
This seems to me like a rather basic question, and I cannot possibly be the first who wants to do this? Any help appreciated!
  • Oct 5, 2015 11:46 AM UTC
Hi
You're on the right track, you should probably not use the old job submitter service, but rather the new
<server>/transformations/commands/submit/<repository>/<workspace>
It will allow you to POST your published parameters.
For the notification, be sure to specify the topics JOBSUBMITTER_ASYNC_JOB_SUCCESS/FAILURE in the wizard when publishing the workspace on FME Server. On the server, create a new subscription that is alerted by these two topics and sends you the necessary signal (mail or other).
David
sigtill
Forum|alt.badge.img+25
  • Oct 5, 2015 12:23 PM UTC
And it works correctly through the Jobsubmitter interface on fmeserver, so the topics are set correctly and the subscription is the standard subscription auto-generated by FME Server
  • Oct 5, 2015 12:24 PM UTC
Ah, great to know! This also cleared up something for me: Job submitter is the old way, the REST api Endpoint I'm using is the right one.
However, I still cannot get this to work. I'm now sending a POST request to /fmerest/v2/transformations/commands/submit/REPO/WORKSPACE?opt_requesteremail=someone@example.com&opt_servicemode=async&opt_showresult=false
with the body:
{ "FMEDirectives": {}, "NMDirectives": { "failureTopics": [ "JOBSUBMITTER_ASYNC_JOB_FAILURE" ], "successTopics": [ "JOBSUBMITTER_ASYNC_JOB_SUCCESS" ] }, "TMDirectives": { "rtc": false, "description": "description", "priority": 5, "tag": "linux" }, "publishedParameters": [ { "name": "geomCoordSys", "value": "EPSG:4326" }, { "name": "geomPoint", "value": "{\\"type\\":\\"Point\\",\\"coordinates\\":[10.677337646484375,59.923194464901037]}" }, { "name": "Buffer", "value": "552" } ], "subsection": "REST_SERVICE", "workspacePath": "\\"Analyseplattform_test/Enkel_geometri_og_buffer/Enkel_geometri_og_buffer.fmw\\"" }
However, the email_to parameter I try to set on NMDirectives disappears when I query
/fmerest/v2/transformations/jobs/id/JOBID/request
This parameter (the email_to) seems to be the only missing parameter now, do you know how I can pass that in using the transformations/commands/submit/REPO/WORKSPACE path?
  • Oct 5, 2015 12:51 PM UTC
Hi
If you set the topics when publishing the workspace on FME Server, I do not think you need to set the NMDirectives.
Also, I guess that you've played around with the interactive API documentation at http://docs.safe.com/fme/html/FME_REST/? It's quite helpful in letting you construct sample requests.
David
  • Oct 5, 2015 1:06 PM UTC
Hmm.. This may be due to my lack of understanding of FME-terminology, but to me the main problem seems to be "How to specify the email to send the message to".
As far as I understand things, this should NOT be a Published parameter on the workspace itself, and for the jobsubmitter the email is specified using the opt_requesteremail property. However, I cannot find a way to add this property to the Post Body of a request to teh REST API. I've tried this:
-  setting it on the URL itself: did not work
- adding it to NMDirectives: did not work
- adding it to Published parameters list: Threw an error
So, I'm at a loss here.
  • Oct 6, 2015 11:10 AM UTC
Hi Guys,
The transformation/commands api seems to support "NMDirectives" so you can specify the success and failure topics but it doesn't seem to support any other NMDirectives.  So I don't think that can work because you can't pass the email_to address.
Can you use the Job Submitter Service?  Then this should be possible with POST or GET if you specify the following opt parameters:
opt_requesteremail = <emailaddress>
I'll follow-up in more detail via the support case we have for you.
Ken
  • Oct 6, 2015 11:50 AM UTC
Yeah, I found out that adding email_to to the NMDirectives did not work. Strange, is there any logical reason for that?
As much as I would like to use the REST API I'd rather have a working solution, so after "arguing" a bit with the Job Submitter Service (and after some more thinking, the Data Download Servcie). This works, but I ran into some other trouble (related to passing GeoJSON as a published parameter). I at first has to do some replacing og {, [ , and ", (to <bracketstart> etc etc) But SigTill found another way to define a PublishedParameter Geometry, and this solved the issue.
So: current status: This is now working using the DataDownload Service, altough I would really like this to work using the REST API as well. Rather difficult to dig around in several disconnected APIs, trying to understand what works and not.
  • Oct 6, 2015 12:10 PM UTC
Yes agreed,
We have a longstanding task to include the services in the REST API. The other thing that would help is to allow full messages in the NMDirectives for the existing transformation methods - to be honest this is the first time that particular issue has come up that I know of.
Thanks
Ken
  • Oct 6, 2015 12:20 PM UTC
Great to hear you have it on the drawing board at least!
Hmm, maybe my use-case is a bit strange then? I would think it fairly common to be able to start a job using the REST api and have a response sent to a user-defined email. Or do you think this is an uncommon use-case or do people solve it in other ways?
The most frustrating thing for a developer not knowing FME-jargon is juggeling the concepts of REST-api, Jobsubmitter and DownloadService (and maybe more). I guess there are reasons behind this division, but they are very unclear to me and they do make the whole API more difficult to wrap your head around.
Anyways: This seems to be working now, thanks for all suggestions and help from both David and Ken!
