Using Previous Versions of Custom Transformers
  • Jul 28, 2015 5:18 PM UTC
  • 83 views
I made a custom transformer and exported it to the network. Next I made a new version of the transformer. When I open the transformer for edit, FME asks which version do I want to edit. This is okay.
However, when I add the the transformer to an FME script, it puts in the latest version. What if the FME user wants to use a previous version? Is there a way?
Thanks
Best answer by david_r
Hi
The only way to do it is to install an older version of FME (in a separate directory) and then copy-paste the old transformers into the new workspace.
David
  • Jul 30, 2015 8:44 AM UTC
Hi
David
