Using a scripted parameter to return values for choice parameter ?
  • Jun 20, 2025 12:57 PM UTC
  • 163 views
lifalin2016
Forum|alt.badge.img+42
Hi all.
Is it possible to use a scripted parameter in a workspace to populate the items for a choice parameter ?
So far I’ve had to manually edit the choice list whenever new items needed to be added, but potentially it’s possible to create all the items automatically with a query to a database. This would release me from having to update it manually.
The example I’ve found only talks about returning a single text, but a choice parameter needs a list of display+value pairs.
Any insight is welcome.
Cheers
hkingsbury
Forum|alt.badge.img+73
  • Jun 22, 2025 9:19 PM UTC
Kinda - something i’ve been exploring (when i’ve had time!)
You will need to create a transformer (not a custom transformer) using the SDK. In 2024 onwards you can have a dynamic scripted selection populate by python - https://docs.safe.com/fme/html/fpkg-sdk/advanced/scripted-selection/
alexbiz
Forum|alt.badge.img+35
  • Jun 23, 2025 12:03 PM UTC
You might be interested in a new undocumented FME Flow feature present in 2025.1 beta b25583 :
lifalin2016
  • Jun 24, 2025 6:36 AM UTC
Thanks ​@hkingsbury
I’ll look into it.
lifalin2016
  • Jun 24, 2025 6:38 AM UTC
Thanks ​@alexbiz
Our servers are still 2022, so I’ll need to defer this to when they’re being upgraded.
But thanks for the heads-up.
