User is not authorized - publishing workspace to FME Flow from FME Form
  • Jul 29, 2025 2:43 PM UTC
  • 5 replies
  • 353 views
sapplezyw
I get the following error when attempting to publish a workbench from FME form to FME Flow:
User is not authorized.
The specified user credentials were not authorized to perform this action. Ensure with your server administrator that your user credentials are authorized to perform this action.
Publish Failed (Not Authorized) - Ensure that credentials are correct, and that user has sufficient privileges.
I’m publishing using an account with superuser access. I’ve also managed to upload the workbench directly to a the folder using the FME Flow interface
FME Form: 2025.0.1.0 (20250327 - Build 25220 - WIN64)
FME Flow: FME Flow 2025.0.1
sapplezyw
  • Jul 29, 2025 3:16 PM UTC
When creating an automation and attempting to save it, i’m getting an ‘You are forbidden error’ with the same superuser account
donalmateer
Forum|alt.badge.img+13
Hi ​@sapplezyw,
A few questions to help understand the case a bit better:
Are you seeing this issue for all workspaces or specific workspaces in certain repositories on Flow?
You mentioned that you are publishing as superuser. Is it FME Flow's default superuser account or another superuser account? On the User Permissions in the Web UI, if you look at the user, do they have publish permissions to the repositories?
Is this a system user or an AD/LDAP/SAML imported user ? Are you able to manually login to the FME FLow Web UI directly as that user ?
sapplezyw
  • Jul 31, 2025 10:00 AM UTC
Hi ​@donalmateer ,
Thank you for the reply - To answer your questions:
  • I’m seeing it for all workspaces in all repositories
  • It’s another user that has been given superuser role
  • Yes I have also given publishing rights on all repositories
  • The user is a system user
  • Yes I can manually login and upload/replace workbenches through the flow interface without issue
When I try to save an existing automation that I own, I see a small ‘You are forbidden’ badge. This does not effect my ability to save the automation.
I also tried creating a new user with superuser permissions but that had the same issue. We also attempted to setting the WAF policy in Azure for "Inspect Request Body", to False. That did not work either - We got this idea from someone having a similar issue
itsmatt
Forum|alt.badge.img+48
  • Jul 31, 2025 11:11 AM UTC
Did you read this thread at all?
Theres a comment at the bottom using FME 2025.1. could be related. Although that would usually effect all users of FME Flow.
One clue might come if you open up you browser developer tab when trying saving your automation. clicking the save button will cause a series of calls from the client to the server, possibly one of these calls is failing.
Have you tired restarting you FME Flow?
sapplezyw
  • Aug 1, 2025 8:57 AM UTC
Thanks ​@virtualcitymatt, I tried to save the automation with developer tools and I can see a 403 error related to Microsoft azure application gateway. I’ll try and do some testing with out cloud engineers to track the setting we need to change:
