use same feature type (from one reader) multiple times in one workspace
  • Feb 1, 2019 1:50 PM UTC
  • 126 views
reservoirdog
Forum|alt.badge.img+12
Dear Community!
A thing which bothers me since a long time and I couldn't find any similar thread in the knowledge center:
I have very large workspaces where multiple "things" are done with data.
Quite often I have to use the same Feature type (of a reader) multiple times in this workspace
at different locations. Is there any way to use the same datasource (feature type) at multiple places
in a workspace? Only workaround I see would be to use a feature reader on these "different locations".
Problem with this is, that I want to quickly switch data-sources, and using a feature reader you have to remember to change the datasource there also...
So, best way for me would be the ability to "copy" feature types (of a reader).
Any alternative way to achieve this?
Thx and beste regards from switzerland,
Chris
Forum|alt.badge.img+63
I would not recommend reading the same file more than once unless you absolutely have to.
You can simply connect one feature type to multiple transformers:
That way the data only gets read once (it does get duplicated internally when you're splitting streams of course)
If you have a large, complex, workspace this can become a bit unwieldy so what you can do is right-click on a connection and choose "create tunnel"
That connection is then hidden from view, so it doesn't matter anymore whether both ends of the tunnel are very far apart.
I hope this is what you were looking for :)
reservoirdog
  • Feb 1, 2019 2:20 PM UTC
Exactly what I was looking for... Didn't know this "tunnel-function" exist...
Very useful, thanks a lot and have a good weekend..
