Unicode for Python Caller
  • May 8, 2019 3:12 PM UTC
  • 85 views
I have a unicode string that looks like:
Lat: 49° 16.578', Lng: -123° 7.3'
In a standalone Python script I can find the unicode characters by putting this at the top of my script:
# -*- coding: utf-8 -*-
However, this doesn't work in the PythonCaller. Is there a way to do this?
  • May 8, 2019 3:24 PM UTC
Maybe not the answer you're looking for, but switch your workspace to use Python 3 if you can. Unicode is much, much simpler then.
giosp
Forum|alt.badge.img+7
  • May 8, 2019 3:27 PM UTC
Hi, try this when you print the string text.encode('utf-8')
  • May 8, 2019 3:48 PM UTC
No, I get: 'ascii' codec can't decode byte 0xc2 in position 7: ordinal not in range(128)
  • May 8, 2019 3:52 PM UTC
Looks like Python 3 is going to do it. No conversion needed, it just understands the unicode characters.
