Understanding parallel processing in FME Form
  • Mar 28, 2025 5:51 PM UTC
  • 5 replies
  • 363 views
nic_ran
Forum|alt.badge.img+20
I’m using FME 2023.2.
I thought I understood parallel processing but clearly there are some intricacies that I don’t understand and I’d appreciate any insights people can provide.
I have a custom transformer that processes Lidar tiles and takes some time to run, so I enabled parallel processing and saw some significant performance improvements with my test set of 20 tiles.
However, when I enable the full data set of 10,000+ files I get an error:
2025-03-28 11:26:41|  63.6|  0.0|ERROR |Could not bind port to socket
2025-03-28 11:26:41|  63.6|  0.0|ERROR |Failed to create transporter
2025-03-28 11:26:41|  63.6|  0.0|ERROR |TransporterSender (TransporterFactory): An error has occurred. Check the logfile above for details
2025-03-28 11:26:41|  63.6|  0.0|ERROR |An error has occurred. Check the logfile above for details
2025-03-28 11:26:41|  63.6|  0.0|ERROR |f_25 (TransformFact): Transformer 'ProcessSingleTile': Unable to create worker; try reducing the parallelism level (currently 'MODERATE') or the number of groups (7521 seen so far, 1000 considered borderline, 10000 close to upper limit in best possible scenario)
So, what I don’t understand is, why does FME try to establish over 7000 processes? I thought the number of processes was limited based on the machine architecture (# cpu’s) and the license level?
Best answer by itsmatt
Each group is communicates with the main process over an ephemeral port. The port range is limited and I think this is what is the limiting factor although I’m not 100% on that at all.
When groups are ordered and you are processing by group I would hope the FME would just reuse ports, however, it’s possible that this isn’t happening and this is why this issue is possing up. I’ve run into the same issue are what you’ve hit and due to time pressure I was forces to use a WorkspaceRunner instead I’m not really sure if this is an option for you though.
Forum|alt.badge.img+63
The number of concurrent processes is indeed limited by license level and machine architecture and it has been my understanding that if there’s more than can be handled in one go they’ll just have to wait.
itsmatt
Forum|alt.badge.img+48
  • Apr 2, 2025 9:39 AM UTC
nic_ran
  • Apr 2, 2025 4:03 PM UTC
​@virtualcitymatt thanks for that answer. I was considering the WorkspaceRunner but parallel processing is faster (if it works). I was able to “batch” my parallel processing calls to reduce the number but you end up losing visibility of what’s going on inside the custom transformer. It would be nice if FME would just handle it and not go beyond it’s own limits and die!
Interesting observation on the port range.
nic_ran
  • Apr 2, 2025 4:15 PM UTC
​@redgeographics I thought FME would just wait as well if the limit got exceeded but that’s not what’s happening for me. FME is just going beyond its limits and crashing.
Yeah, I feel that that shouldn’t happen really.
