Unable to run the workspace from newly installed FME server 19
  • Dec 16, 2019 11:13 AM UTC
  • 123 views
nag
Hello Team,
We have installed FME Server 2019 and published a workbench which was running fine with the FME Server 2015. But in newly installed 2019 server it was throwing following error.
oordinate system named NiSource_AE_US_Foot does not exist.
2019-12-12 08:49:53| 23.7| 0.0|WARN |Failed to get parameters for coordinate system `NiSource_AE_US_Foot' -- No definition was found for coordinate system `NiSource_AE_US_Foot'
2019-12-12 08:49:53| 23.7| 0.0|INFORM|FME API version of module 'GEODATABASE_SDE' matches current internal version (3.8 20190621)
2019-12-12 08:49:53| 23.7| 0.0|INFORM|Writer `GEODATABASE_SDE_1' of type `GEODATABASE_SDE' using group definition keyword `GEODATABASE_SDE_1_DEF'
2019-12-12 08:49:53| 23.7| 0.0|INFORM|An ArcGIS license is already checked out. The product checked out is 'Advanced'
2019-12-12 08:49:53| 23.7| 0.0|INFORM|Installed ArcGIS version is '?.?'
2019-12-12 08:49:53| 23.7| 0.0|ERROR |An error occurred while attempting to retrieve the connection parameters from the connection file 'E:\\SDEConnections\\GPSPreProdSDE\\sde@wgisdg12KY.sde'
2019-12-12 08:49:53| 23.7| 0.0|ERROR |A fatal error has occurred. Check the logfile above for details
Could somebody help me to get out of this issue??
Thanks in advance.
Thanks..
Nagendra
Best answer by redgeographics
It looks like that's a custom coordinate system, you'll need to add that to your FME Server engine(s), see here for the docs on that.
Forum|alt.badge.img+63
nag
  • Dec 16, 2019 4:22 PM UTC
@redgeographics I have uploaded custom coordinates file to server and tried again now the error message changed, It is something related sde connection. do we need to make any sde connection in the server? Could you please check following error and provide the solution.
Trying to find a DYNAMIC plugin for writer named `GEODATABASE_SDE'
2019-12-16 10:16:19| 17.8| 0.0|INFORM|FME API version of module 'GEODATABASE_SDE' matches current internal version (3.8 20190621)
2019-12-16 10:16:19| 17.8| 0.0|INFORM|FME Configuration: Destination coordinate system set to `NiSource_AE_US_Foot'
2019-12-16 10:16:19| 17.8| 0.0|INFORM|Coordinate System `NiSource_AE_US_Foot' parameters: CS_NAME=`NiSource_AE_US_Foot' DESC_NM=`Albers Equal Area, NAD83 Datum, NiSource, 6 States, FOOT_US' DT_NAME=`NAD83' EL_NAME=`GRS1980' GROUP=`NiSource Group' MAP_SCL=`1.0' ORG_LAT=`23' ORG_LNG=`-96' PARM1=`29.5' PARM2=`45.5' PROJ=`AE' QUAD=`1' UNIT=`FOOT' X_OFF=`0.0' Y_OFF=`0.0' ZERO_X=`0.001' ZERO_Y=`0.001'
2019-12-16 10:16:19| 17.8| 0.0|INFORM|Writer `GEODATABASE_SDE_1' of type `GEODATABASE_SDE' using group definition keyword `GEODATABASE_SDE_1_DEF'
2019-12-16 10:16:19| 17.8| 0.0|INFORM|An ArcGIS license is already checked out. The product checked out is 'Advanced'
2019-12-16 10:16:19| 17.8| 0.0|INFORM|Installed ArcGIS version is '?.?'
2019-12-16 10:16:19| 17.9| 0.0|ERROR |Could not open the Enterprise Geodatabase. The error number from ArcObjects is: '-2147155644'. The error message from ArcObjects is: {Cannot connect to database because the database client software failed to load. Be sure the database client software is installed and configured correctly.}
2019-12-16 10:16:19| 17.9| 0.0|ERROR |Please ensure the connection parameters are correct (server=`sde', instance=`sde:oracle$sde:oracle11g:wgisdg13', user=`sde', password=`***', database=`', version=`SDE.DEFAULT')
2019-12-16 10:16:19| 17.9| 0.0|ERROR |A fatal error has occurred. Check the logfile above for details
2019-12-16 10:16:19| 17.9| 0.0|ERROR |... Last line repeated 2 times ...
Thanks..
Nagendra
nag
  • Dec 16, 2019 4:35 PM UTC
Hi redgeog,
I got the issue, We were using deprecated version of python. it was causing these issue. Now it is running fine. Thanks for your valuable time and support.
Thanks...
