Transformer requires build XXX
  • Jul 12, 2018 12:16 PM UTC
  • 122 views
dbryantgeo
Forum|alt.badge.img+7
I am attempted to add the FMEServerEmailGenerator to a workbench on build number 17291, however I receive an error stating that I must upgrade to 177725 to use the transformer.
I know this sounds pretty obvious, but another workbench on the same build number (17291) does not prompt me to upgrade.
What might be causing this conflict?
Forum|alt.badge.img+63
So for clarification: you're also trying to add the FMEServerEmailGenerator in the 2nd workspace?
dbryantgeo
  • Jul 12, 2018 12:29 PM UTC
Yes, attempting to add the generator to both workspaces, one successfully and the other not so.
jdh
Forum|alt.badge.img+41
  • Jul 12, 2018 4:33 PM UTC
What happens if you copy the FMEServerEmailGenerator from the workspace that works to the one that doesn't, rather than accessing ti directly from the hub?
rylanatsafe
Forum|alt.badge.img+14
Hi @dbryantgeo – you might try clearing the location where FME Hub/Store downloaded items appear, and reopening FME Workbench. The FMEServerEmailGenerator is a custom transformer and perhaps there is some sort of conflict.
macOS: ~/Library/Caches/Safe Software/FME/FME Store/
Windows: ~\\AppData\\Roaming\\Safe Software\\FME\\FME Store\\
If that does not work – try removing all instances of the FMEServerEmailGenerator from the workspace (after making a backup of it!) and then re-add it. When you have an embedded custom transformer in the workspace, FME will load that version of it – could be some odd corruption.
Hope that helps! The suggestions in the comments directly under your post might be helpful too.
