Traditional Versioning & GlobalIDs with Esri ArcGIS Portal Feature Service Writer
  • Jul 15, 2024 5:32 PM UTC
  • 251 views
sammy
Forum|alt.badge.img+27
I know in the Esri ArcGIS Portal Feature Service writer there are parameters to control writing out with branch versioning.
Is there similar functionality for traditional versioning?
If yes, is there a way to have traditional versioning and preserve Global IDs using the Esri ArcGIS Portal Feature Service writer?
Best answer by saraatsafe
Hi @sammy,
I’m not sure if Traditional Versioning works with Portal; you’ll likely need to stick with Branch Versioning which is supported by Portal. For more info, please take a look at these two articles from Esri: Branch version scenarios & Traditional version scenarios.
sammy
  • Jul 16, 2024 12:16 PM UTC
I’ve checked documentation here but it only mentions branch versioning: https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/arcgisportalfeatures/arcgisportalfeatures_writer.htm
I ran a test workbench in that preserves Global IDs and the destination feature class is traditionally versioned but I got this error in FME Flow:
ArcGIS Portal Feature Service Writer: Writer configured to use Global IDs, but this is not supported by the Feature Service
Python Exception <GlobalIdUnsupported>: FMEException: 928251: ArcGIS Portal Feature Service Writer: Writer configured to use Global IDs, but this is not supported by the Feature Service
I don’t really know what I should change/try next to see if I can get this to work.
saraatsafe
Forum|alt.badge.img+13
  • Jul 18, 2024 7:10 PM UTC
Hi @sammy,
