Tiling a DWG
  • Sep 4, 2024 10:24 AM UTC
  • 69 views
bmwhbmwh
Forum|alt.badge.img+4
Hello, anyone knows how to split a DWG into tiles?
i can make it happen with tiler however i cannot split it or simply chhose the tile i want to export
Forum|alt.badge.img+63
The Tiler will add attributes (_column and _row) to all output features, you can use those in a fanout to write to different files (check the Fanout Dataset parameter on the writer in the navigator) or use a TestFilter to select a specific tile.
