Strings with numbers
  • Jan 27, 2016 2:55 PM UTC
  • 5 replies
  • 142 views
pushpa
Forum|alt.badge.img+9
I have a Shapefile with 9000 records and one of the attribute columns contain strings (numbers and letters). Column width is set to 4 characters
I need to find all records with last character is a "letter" and delete that letter.
ie:
ST4W
S4W
Above records I would like to delete "W" from the records
Could someone help me to do this using FME?
thanks
Best answer by erik_jan
You can use the StringReplacer, use the regular expression [a-zA-Z]$ to remove the last character if it is in the mentioned range and replace with nothing. Or use [a-z]$ and case sensitive No.
erik_jan
Forum|alt.badge.img+26
  • Jan 27, 2016 3:00 PM UTC
davideagle
Forum|alt.badge.img+21
  • Jan 27, 2016 3:03 PM UTC
SubStringExtractor to extract the 4th character to new attribute.
AttributeClassifier to test that attribute to see if its Alphabetic.
Records that pass go through another SubStringExtractor and extract values 0 to 2 or 0 to -2 from the original attribute to a new attribute or overwrite the old one.
Or do some Regex magic...no doubt about to appear below this post...
davideagle
or above this post... I was too slow!
pushpa
  • Jan 27, 2016 3:48 PM UTC
Thanks. not sure what I am doing wrong,
I didn't get the results I expected.
davideagle
  • Jan 27, 2016 3:57 PM UTC
Here you go if you want to try it with a couple of standard Transformers.
stripofflastchar.fmw
