Stop Queue if there is a failure
  • Aug 3, 2018 9:10 PM UTC
  • 40 views
We are using FME to replicate spatial records between databases. The replication workbench is dynamic and being triggered by Informatica Power Center via async web service call. We have a dedicated engine for Replication because these calls need to stay in order. Does anyone have any best practices on making sure the jobs in the queue do not start running if one fails?
Forum|alt.badge.img+63
Two ideas come to mind:
  • Make use of Notifications. Success of workpace1 triggers a notification which in turn triggers a 2nd workspace to run. Failure of workpace1 triggers another notification for error handling/reporting (or nothing at all)
  • Use FMEServerWorkspaceRunners from a master workspace, you can then set up that master workspace to handle success or failure of the child workspaces.
The 2018 FME Server Authoring course has an excercise covering that 2nd approach.
