Status code 413 Publishing Workspace to the server
We have a workspace file with a size of 2140kb, when we tried to upload to FME server we are getting a publish failed error:
Publish failed - FME Server encountered an error.
Request to https://myserver/fmerest/v3/repositories/dev/items returned status code 413.
HTTP Error 413 is Entity Too Large, where can I change this restriction on FME Server?
Thanks.
Best answer by geosander
If it is a standard FME Server installation (with the built-in Tomcat HTTP server and the default FME Server configuration), this should not happen. My workspaces were over 4MB and I never experienced any problems.
My guess is that your HTTP server configuration is the problem here. Which one are you using? IIS, Tomcat, Apache...?
geosander
Forum|alt.badge.img+7
  • July 10, 2017
I'm using nginx as a reverse proxy, I add to my config:
set client body size to 20M #
client_max_body_size 20M;
And start working.
Thanks!!!
geosander
  • July 11, 2017
velasquezvictor wrote:
And start working.
Thanks!!!
Glad you figured it out and thanks for sharing the solution. It helps others who might have the same issue!
