SQLSERVER Reader type generates unnecessary warnings
  • Dec 11, 2025 11:34 AM UTC
  • 10 replies
  • 365 views
s.jager
Forum|alt.badge.img+27
Ever since the merging of SQLServer spatial and SQL Server non-spatial Reader types, my SQLCreators and SQLExecutors generate a warning:
Microsoft SQL Server Reader: Table `___FME_Custom_SQL_Statement___' does not include a spatial column. Geometry will not be read
In Form this is easily ignored, but it really messes up my Jobs overview dashboard on Flow, because it results in quite a lot of listings with warnings that do not need checking. And I can’t seem to find a way to tell FME that yes, I know, there is no geometry coming through in this sql, don’t worry about it because I did not select it - on purpose (or because it does not exist).
I really do not want to turn off all warnings generically, I am just searching for a way to stop this particular warning. Before the merge it was easy: just use the non-spatial type, and the warning would go away. But that is not an option anymore unfortunately...
  • Dec 11, 2025 12:25 PM UTC
I can just add that this is a fairly common request with our clients: they want to get rid of warnings that aren’t important to their process, so that “real” warnings get better visibility in the Flow jobs overview.
So far I’ve only managed to remove certain warnings by introducing transformers specifically to get rid of them (e.g. CoordinateSystemRemover, Decelerator, BulkAttributeRemover, etc...) but I find it unsightly and it complexifies the workspace for no good reason.
It would be fantastic if there was a way to ignore known warnings (using wildcards?) on a per-workspace basis.
s.jager
  • Dec 11, 2025 12:43 PM UTC
Agreed. It would improve my jobs-dashboard tremendously. I know in my dashboard I could get the logfile, parse it, and filter out these warnings, but that would slow the dashboard down...
To be honest, I don’t even understand why this particular one (“does not include a spatial column. Geometry will not be read”) has to be a warning at all. Information maybe, but even then: I wrote that SQL statement that the transformer has to execute myself, so I know there’s no geometry in the select. Why should that be a warning? It’s my own doing! It makes no sense to me in this case...
  • Dec 11, 2025 12:48 PM UTC
Fully agree.
I recently had a case where the Clipper gave a warning about being unable to use 0 for tolerance and that it had calculated a different value. The problem was that this older version of the Clipper didn’t even have the tolerance setting! The solution was to update the Clipper and make sure the tolerance was set to automatic, and just hope that all the new settings that were introduced didn’t change the result.
Forum|alt.badge.img+54
  • Dec 11, 2025 1:03 PM UTC
There’s lots more that have cropped up from 2024 onwards
“Resetting a database that is still referenced”
“No query delimiter specified; SQL will be treated as a single statement. To specify the delimiter token, write FME_SQL_DELIMITER <token> as the first line of SQL text”
Warning message: Resetting a database that is still referenced. | Community
s.jager
  • Dec 11, 2025 1:14 PM UTC
Oh yes, the no-query-delimiter one. I’ve got some quite complicated sql’s, using CTE’s and unions - that one always crops up with those kinds of statements.
Never encountered the resettng-database one though, at least not that I remember.
But the spatial column one only started showing after the introduction of the single SQLSERVER reader-type, so that is fairly recent. The no-query-delimiter I’ve seen for a looong time, if memory serves me right I’ve already encountered that one when still using 2014.
s.jager
  • Dec 15, 2025 10:07 AM UTC
Something else I just noticed (because the scheduled workspaces all failed!) with the new combined SQL Server type, is that automatically a geometry column is added to the Writer configuration. I have a lot of workspaces that do NOT write any geometry, but yesterday a bunch of them failed because
“Spatial Column ‘GEOM’ with type ‘geometry’ does not exist in table ‘<tablename>’.”
Due to the fact that this configuration is only shown on the User Attributes tab, it is extremely easy to miss, also because it does not show a red triangle when you feed it features without geometry.
I am less and less convinced upgrading was a good idea, tbh...
desiree_at_safe
Forum|alt.badge.img+24
Hi folks! Thank you for bringing this to our attention.
I can see how filtering warnings and log files would be helpful in debugging. It’s a great idea and I’d encourage you to Submit an Idea if you haven’t already 😄
Besides that, the jobs failing and that warning message is worth looking into ​@s.jager! We’d love to dig into this a bit more, particularly the upgrade process you took with these workspaces. It would help us better understand the underlying issue and improvements that could be made.
If you prefer, and if you haven’t already, you can also submit a support ticket with us
[internal: FMEENGINE-89051]
s.jager
  • Jan 7, 2026 3:25 PM UTC
The upgrade process is fairly easy: right-mouse-click on the writer in the Navigator, and select Update Writer/Reader.
You then get for the database connection only one choice, when there used to be two: a Spatial one and a Non-Spatial one. Since the merge of those two, FME automatically assumes geometry, on every single table - and I frequently deal with objects that have no geometry. On all reading transformers that generates the warning from my first post, on writers it generates the warning from my previous post in this thread - and with the writers, it fails the translations. on the readers it just messes up my dashboards, because I get 5000 warnings that my statement does not include a spatial column, and that therefore no geometry will be read…. No shit Sherlock! But just on the off chance that warning 3475 is actually a warning that I need to do something about, I still have to check them… I might actually invest the time in letting FME do that for me ….
s.jager
  • Jan 20, 2026 2:18 PM UTC
OK, this one just got more annoying: Added a Writer in order to delete a bunch of duplicate rows from my table. Feature Operation is set to Delete, Table Handling is set to Use Existing, Match Columns is set to the Primary Key of that table (and since I do a select * from that same table, I am guaranteed of that PK-column having a unique value). So when trying to run, the workspace fails, with this error message:
84 2026-1-20 15:06:19 | Microsoft SQL Server Writer: Spatial Column 'GEOM' with type 'geometry' does not exist in table 'xxx.xxxxxxxxx'. Please specify an existing spatial column to write to
Why? First of all these are rows from a join-table without any geometry, secondly: the Feature Operation is set to Delete. How does that warrant a check on a geometry column being there or not? All that matters is whether the Match-column is there or not.
desiree_at_safe
As an update, I'm glad to say we have made fixes for these issues.
The unnecessary warning messages from SQLCreator/SQLExecutor about missing spatial columns (when the table doesn't have spatial columns) have been fixed! Please download FME 2026.1+ for this change: FME Downloads - Latest Version
You may still experience a similar warning with the SQL Server Reader on non-spatial tables, but that fix should be coming in FME 2026.2 (expected sometime in June this year).
I hope these updates help! Thank you all for flagging this 🙂
[INTERNAL: FMEENGINE-89051 / FMEENGINE-89633]
