SQLExecutor Oracle Connection Parameter
  • May 29, 2014 11:11 PM UTC
  • 61 views
yakker
Participant
Hi All,
I was wondering if it Is possible to connect to a Oracle Non-spatial database without having the Service name set up in the tnsnames.ora file?
I'm using a Esri ArcSDE reader in my workbench so I am trying to use the same parameters to keep it simple to deploying on another machine.
Thanks
Best answer by david_r
you can use an Oracle EZCONNECT (http://www.orafaq.com/wiki/EZCONNECT) string on the format username/password@[//]host[:port][/service_name]
Example:
David
  • Jun 2, 2014 7:50 AM UTC
Example:
David
