Set Sampling Amount parameter from an incoming attribute?
  • Jul 31, 2015 4:33 PM UTC
  • 58 views
jwe
Hello, ?is it possible to set the "Sampling Amount" parameter of the transformer "Sampler" from an incoming attribute? I understand this value could theoretically change per row of data, but it would simplify our process greatly.
Thanks!
Using FME 2015.1
Best answer by fmelizard
Dont think its possible, check the docs to be sure....
In that case I would:
Add a counter (start with 1) and a tester to test the _count value againts the attribute value.
fmelizard
Forum|alt.badge.img+22
  • Jul 31, 2015 7:06 PM UTC
jwe
  • Aug 4, 2015 2:01 PM UTC
Thanks for the quick reply. Looks like I'll probably stick with changing up my process… it will be better in the long run. ?
