Sending data using Websocket
  • Jul 16, 2020 2:09 PM UTC
  • 7 replies
  • 72 views
mygis
Forum|alt.badge.img+14
I am using the websocketSender transformer to stream some data; when I am using the template in the data to transmit as below:
"ws_op" : "send",
"ws_msg" : "FME Rocks"
I have no issues; however when replacing the "FME Rocks" with the attribute name, nothing happens. For example, if I have an attribute named "id", here is what I do:
"ws_op" : "send",
"ws_msg" : fme_get_attribute("id")
I don't get any errorr, it is just that data is not transmitted compared to the first case.
Any pointers would be much appreciated.
Thanks.
Lyes
Best answer by mygis
Hi, I created the string using the AttributeCreator then assigned the created string to Data to Transmit. The result was something like this:
"ws_op" : "send",
"ws_msg" : @Value(id)
I can now transmit data successfully from one workspace to another.
afavaccio
  • Jul 16, 2020 3:52 PM UTC
Hi @gisinnovationsb,
you can try this:
"ws_op" : "send",
"ws_msg" : ("id")
or this:
ws_op: 'send',
ws_msg: '@Value(id)'
HTH
Andrea
mygis
  • Jul 17, 2020 6:33 AM UTC
"ws_op" : "send",
mygis
  • Jul 17, 2020 6:34 AM UTC
you can try this:
"ws_op" : "send",
"ws_msg" : ("id")
or this:
ws_op: 'send',
HTH
Andrea
Hi @afavaccio both didn't work. I found the solution please refer to my reply and thanks for the help.
itsmatt
Forum|alt.badge.img+48
  • Jul 17, 2020 6:42 AM UTC
"ws_op" : "send",
Haha, gosh very sensitive to the syntax. Not what I'm used to with FME. Thanks for sharing your results.
mygis
  • Jul 17, 2020 7:02 AM UTC
Hi Matt, I will accept your comment as the response ;)
  • Jul 17, 2020 9:46 AM UTC
       "ws_op"  : "send",
I think the data to transmit should be a valid JSON text.
If id was a numeric value - e.g. 100, your expression would be a valid JSON.
"ws_op" : "send",
"ws_msg" : 100
However, if id was a non-numeric value - e.g. ABC, the expression wouldn't be a valid JSON.
"ws_op" : "send",
"ws_msg" : ABC
In the case, the id should be quoted with double quotations, as in.
"ws_op" : "send",
"ws_msg" : "ABC"
  • Jul 17, 2020 9:50 AM UTC
"ws_op" : "send",
I had a similar issue. The explanation that I got in https://knowledge.safe.com/questions/98505/send-json-via-websocket.html from @denniswilhelm (which I've verified too) is: "fme_get_attribute automatically escapes " to \\" which isn't done by the @Value command. In a JSONTemplater you can also use fme:get-json-attribute("yourAttributeName") to explicitly load insert valid JSON values."
Hence the difference between the two, seemingly, identical ways to get data from the attribute.
