Search Envelope on FeatureReader
  • Apr 27, 2018 1:37 PM UTC
  • 14 replies
  • 299 views
Hello,
Any idea why when I am trying to use the search enveloppe option to filter only geometry features within a specified box (see file attached) I always got: Error running translation.
Otherwise without enabling the search envelop option my workflow works fine.
Thank you in advance.
erik_jan
Forum|alt.badge.img+26
  • Apr 27, 2018 1:42 PM UTC
I believe the issue is, that you are reading from XML, a non spatial format.
So the search envelope has no geometries in the data source to intersect with, and will therefor not read any data.
  • Apr 27, 2018 1:51 PM UTC
Thank you for your answer @erik_jan !
You are right I am reading from XML but then I have access to Feature with Geometry inside.
So let me rephrase :) How can I filter then those Geometry which are within a box ? Using GeometryFilter ?
Thank you again.
  • Apr 27, 2018 2:04 PM UTC
I think I found a way to do it by:
Using a Creator a creating a Box
Using a Spatial Filter and attaching my Box to the Filter input and my Feature to the Candidate input.
Thanks.
erik_jan
  • Apr 27, 2018 2:11 PM UTC
Thanks.
If you want only the inside parts, you could also use the Clipper transformer.
  • Apr 27, 2018 2:36 PM UTC
Not working well with SpatialFilter I tried with Clipper but I got : Error Running Translation :(
Thank you.
erik_jan
  • Apr 27, 2018 2:42 PM UTC
Thank you.
You might want to test for a valid geometry before feeding features to either SpatialFiler or Clipper, using a GeometryFilter.
Or you can set the parameter to ignore rejected features and continue:
  • Apr 27, 2018 3:02 PM UTC
@erik_jan you are amazing!
I added a GeometryValidator before and everything is running smoothly.
A last, question though, how to remove the clipper itself from the result (the box) ?
I just want the clippee result without the clipper :)
Thanks again.
erik_jan
  • Apr 27, 2018 3:12 PM UTC
The Clipper geometry should not be exported from the Clipper transformer, unless you also connected it to the Clippee port.
About the attributes, you can set it not to merge attributes, but only use Clippee attributes.
  • Apr 27, 2018 3:20 PM UTC
Thanks again.
As u can see from the screenshot attached that the box is exported (it is not connected to the clippee port). Are the Clippee geometries altered somehow by the Clipper Geometry ?
Thank u again.
erik_jan
  • Apr 27, 2018 3:39 PM UTC
Is that actually the box you are seeing, or the combined boundaries of the clipped features from the clippee port?
  • Apr 27, 2018 4:44 PM UTC
Thank u again.
This is the point I don't want combined boundaries. :)
I just want all my Features which are inside a box.
erik_jan
  • Apr 27, 2018 4:47 PM UTC
You can add the outside port and then test on _clipped = 'Yes' (Tester).
That will add the part of the clipped features that is outside the box.
  • Apr 27, 2018 5:05 PM UTC
I don't think I am on the right direction...
Let's restart:
I would like to build a list of all my Features geometry which are inside a defined box (min x, min y, max x, max y) without altering their geometry/attributes.
Thank again!
  • Apr 27, 2018 5:17 PM UTC
I finally managed to do it with my initial idea:
- Creator + SpatialFilter
Thank you very much @erik_jan
