running workspace from python use workspaceRunner no longer works
  • May 23, 2016 7:55 PM UTC
  • 84 views
I have a workspace that I can run without error from the workbench, and I have a python script that also has run it in the past without issue. For some reason, now when I run the workspace via the script, it does not produce an error, but the output files it is writing (KMZ) are empty. I've double-checked all the parameters and they seem to be ok. There is an sde reader, which I did change to read a connection file, vs previously I entered in all the connection information. I'm not sure what's going wrong?
  • May 23, 2016 7:59 PM UTC
I should also mention the path of the workspace changed.
  • May 24, 2016 9:38 AM UTC
The FME log file will most likely tell you why, in particular where there are no more features passing through.
  • May 24, 2016 3:35 PM UTC
Thanks for the tip. I compared the log from the python script run to the one generated when i launched the workspace from workbench. It seems it is not reading the features in the sde geodatabase, but I'm unsure why. I wonder if I need to specify the feature class in the database in the script, in addition to the database itself as a parameter.
  • May 24, 2016 9:52 PM UTC
I've also tried now to run the workspace through command line (i'm on windows), and I get the same results with empty kmz files...
