Running 'part' of a workflow?
  • Nov 18, 2013 8:32 PM UTC
  • 5 replies
  • 73 views
All,
Is it possible to run part of a workflow?
I've got a process that reads 12 feature classes of ~85,000 features each.
I got to the very last one, and it bailed out.*
Can I just re-run that 12th one?
*bailed out because adding a writer takes the DB name of the reader - why?
fmelizard
Forum|alt.badge.img+22
  • Nov 18, 2013 8:45 PM UTC
Search for the feature types to read parameter in the navigator.
Hope this helps.
Itay
  • Nov 18, 2013 8:56 PM UTC
That was it...
...except... I forgot to turn off "truncate table first" on the writer, now I gotta do the whole kit and kaboodle over again anyway...
Good to know regardless!
Thank you!
fmelizard
  • Nov 18, 2013 9:13 PM UTC
Bummer, create a parameter from that too so when you prompt and run you know what the writer settings are.
  • Nov 19, 2013 8:35 AM UTC
another tip for you: most Readers have a "Start feature" paramater (under Advanced in the Navigator) where you can specify the feature number to start your execution with.
David
sigtill
Forum|alt.badge.img+25
  • Nov 20, 2013 11:28 AM UTC
I usually insert a Recorder-transformer in the workflow after alot of heavy processing have been done. And then a Player-transformer to play from that point and disable the normal Readers. Then at the end when the complete workspace is done, I would remove these and run the complete workflow.
