Running a workspace with prompt using a batch file
  • Jun 26, 2017 10:17 AM UTC
  • 5 replies
  • 108 views
Hello everybody,
i know it is possible to run a FME workspace by using a a batch file. But what is the command in the batch to run this workspace with prompt?
With kindest regards,
Felix
Best answer by redgeographics
You could run "fmequicktranslator.exe myworkspace.fmw", that will pop up the Quick Translator with that workspace so your user will get the parameters dialog.
Forum|alt.badge.img+63
  • Jun 26, 2017 11:14 AM UTC
Hi @felixderglueckl
What is suggested above, or run the Workspace in FME Desktop then look at the top of the log file for the command. You don't get the prompt however!
Hi @felixderglueckl
But that wouldn't prompt, right, just take the parameters as they are specified?
  • Jun 26, 2017 12:38 PM UTC
Yep - why I said you won't get the prompt which I know the OP requested but just pitching it out there as a possibility.
mygis
Forum|alt.badge.img+14
  • Jun 26, 2017 12:51 PM UTC
I don't think it is possible to have the prompts popping up when a airspace is run from a batch file. However you could add variables from the dos prompt in the batch file if not mistaken .
