Running a workspace using a .bat file
  • Nov 18, 2015 3:12 PM UTC
  • 137 views
mbaer
When I schedule a .bat file that runs my FME workspace through windows task scheduler it returns a 0x2 error but when I run the .bat file manually it works fine.
mbaer
  • Nov 18, 2015 6:29 PM UTC
It is scheduled with admin rights to the machine so it has rights. I am still getting the same message. What should be in the "Start in " parameter be set to pint to? I have not made any changes to the scheduler besides setting times for the triggers and setting up the action.
  • Nov 23, 2015 8:10 AM UTC
The "Start in" parameter should be set to the FME_HOME directory.
If you still cannot get it to work, consider looking for related error messages in the Windows event logs.
  • Nov 23, 2015 11:08 AM UTC
I checked the error code, and it points to insufficient rights. Just be aware, that the scheduled events run with restricted privileges by default, even though the user might be local admin. You will have to specifically assign full admin privileges on a per-task basis, see here:
Access denied (0x2) error as an administrator in Windows Task Scheduler
  • Nov 19, 2018 2:44 AM UTC
Thanks - yes, I needed to set the FME_HOME directory (same path as FME.exe).
