running a workbench using python
  • October 22, 2019
  • 89 views
tnarladni
Forum|alt.badge.img+23
I would like to run a workspace using python and the code I have is simple, but it's not working. Is there something wrong with my python code or could it be something else?
import subprocess
args = [r"C:\Program Files\FME\fme.exe", "C:\ProgramData\Geocortex\Workflow\FMEScripts\testEmailer.fmw"]
subprocess.Popen(args)
Best answer by tnarladni
I found the problem. It was the syntax. So this thread has a similar line of code, but I noticed that the second argument has double backslashes and no r.
https://knowledge.safe.com/articles/1158/run-an-fme-workspace-from-python-using-fmeworkspac.html
So I tested and found that either I need to put 'r' before the literal string for the path, or escape the '\' with '\\'. And that worked. so here is my new code and this is working.
import subprocess,os,getpass
args = [r"C:\Program Files\FME\fme.exe", r"C:\ProgramData\Geocortex\Workflow\FMEScripts\testEmailer.fmw"]
jdh
Forum|alt.badge.img+40
  • October 22, 2019
You are missing a couple of arguments, like the path to the workspace to be run and optionally any published parameters.
tnarladni
  • October 22, 2019
oops. I posted the wrong code. I edited the question to show my py script
jdh
  • October 22, 2019
I've never used subprocess to run an fme workspace. There is an article on using fmeobjects and the FMEWorkspaceRunner.
tnarladni
  • October 22, 2019
